Schedule question
This will be a simple one for somebody
I want to make a new schedule with "All Object Types" criteria as in the attachment.
But when I select "Element Type" then go to choose "All Object Types" from the drop down it is not there!
How do I select that option?
14 REPLIES 14
I tried that, as soon as I import the scheme the name reverts back to what it was when I exported it
It works for me:
1. I Export "Object Inventory".
2. In the Scheme panel of the Dialog, I change "Object Inventory" to Object Inventory2".
3. I import the XML I just exported. A new Scheme named "Object Inventory" appears in the list. Also, I have the renamed scheme named "Object Inventory2".
Works both in AC18 and AC19.
It will let me rename
But then the main header in the actual scheme stays as the old name
You can simply click into the Header cell of the actual generated Schedule and type a different name for it.
That easy!
Thanks Laszlo
