Schedules - Linked Parameters
I am inerested if Archicad is capable of linking parameters or associating parameters such as header, jamb, and sill details within the object so when a detail is generated and placed as a layout in plotmaker it links to those parameters, does this make sense?
I would love to have a detail somehow linked to parameter within an object!
Currently I am using 9 and will be jumping to 12. Prior to completing my schedule, I have to generate the detail, place it in plotmaker, then I have to go back and select the window, manually input the location of the jamb, header, and sill parameters. Any way of linking those parameters would valuable.
Kim
1 REPLY 1
Djordje
You will be able to link the details in 12 much better than in 9 -not to the library part, but the markers and the detail tool is much more intelligent.
And, brace yourself- no more PlotMaker! On the other hand, PMK is back
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
