Eduardo Bell
Schedules_Wall Surface Calculation (error?)
Hello, I'm trying to use the zone tool to calculate the total wall surface of a small room. As you can see, room xx is 243" perimeter x 11 feet high= 222.75sf. However the schedule generates a 149.62 sf value. Any ideas why or how to get an accurate number?
Generated on AC15 v3602
Thanks,
USA v4.55 to v29) OS Sonoma v 14.6.1
MacBookPro 8-Core Intel i9 16GB ram
AMD Radeon Pro 5500M 4GB vram
Perpetual License Subscriber & Cloud Subscriber
5 Replies 5
Eduardo Bell
Missing file attachment.
Is your zone also 11' high?
Eduardo Bell
Yeah ('8)'), even when I change the zone height the numbers are confusing...
On line Room xx: Wall is still 11' h , changed zone to 5' h x 20.25' perimeter = 101.25 sf , not 68,02 sf as calculated by the 'wall surface' schedule. It has to be a setting elsewhere, but I've gone over all that seem pertinent to no avail...I wish in the future we had a clean interface with less clicks and more centralized commands....
In your schedule I am guessing that the perimeter you show is the "net perimeter".
Try adding in the "wall perimeter" to see if the figures match.
I am thinking maybe your zone is not touching all of the walls.
Eduardo Bell
Yep. Good thinking. Thanks-a-bunch.
