Schedules and Formulas
I understand that from AC22 on you can use formulas. I can easily make schedules that add totals but would like to be able to subtract areas and produce percentages. Typically for project data. Below is a sample of what kind of schedule I would like to create:
I would like to create a schedule that:
Title: "Project Data"
Site Area (zone) sq. ft.
Building Area (zone) sq. ft.
Site Coverage (Building Area / Site Area as a %)
Open Area (Site Area - Building area) sq. ft., %
Calculates Gross Floor Area (zone) sq. ft., by storey, total
Net Floor Area (gross floor area minus exclusions) (zone) sq. ft., by storey, total
Floor Area Ratio (net floor area / site area) sq. ft.
Units By Type (based on zones), by storey, total
Density (units per acre)
same as above using m2 listed next to the sq. ft. numbers
Thomas Allan Palmer
Architect AIBC MRAIC
ArchiCAD 24 MacBook Pro
Mac OS Catalina 10.15.6
11 Replies 11
Barry wrote:
kzaremba wrote:
However, since it's the expression you cant sum it up in schedule... even if I left it as number value.... proc num column on attachment.
'proc num' column has totalled correctly.
Sure Sum did but I meant value in the cell. The proc num shows the only ratio between single apartment to the overall area - so quite useless. I'd expected to sum hole type of apartments. (if you sum up cells in this column you get 29,28).
You have multiple elements with the same 'proc num' result.
Because they are not unique, they show the same figure but the total is correct.
(1 x 5.44) + (6 x 9.67) + (2 x 5.90) +(3 x 8.27) = 100.07
In the scheme settings try turning on the 'flag' icon next to the 'proc num' field.
You should then see sub totals - I hope.
NOTE: this does not work for area, length, width fields, as these do sum as you are wanting them to (which I think is wrong).
But your field is not a true area, length or width so it should work.
