Schedules for more
hi all
now i can see the templates which have windows, doors' schedules,
but can i have more? let say, toilet, tap, objects?
8 Replies 8
vfrontiers
Of Course! You're imagination is the limit...
Simply click over to SETTINGS and create a NEW schedule with new criteria... It's really pretty simple.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
yes
i found it
but not that simple,
i can show all the objects, but i don't how to show just some
and
all the object in a very long schedule,
how can i print it well?
vfrontiers
In the CRITERIA section of the Settings.... you can limit (filter) the objects by LAYER or NAME or PEN COLOR, etc. It will be your job to make sure all the stuff you want in the schedule has that unique identity (all on the same layer, for example) so that your schedule will look right.
Duane
Visual Frontiers
AC3.14 - AC29
iv been doing it by using the lable tool.. lable all of one grupe of itmes i want listed with for example "S1" (for schedule 1 obviously) then if i want another groupe lable them as S2 and so on.. then filter them by there lables..
thho if u need to actually use the lable tool for these items then u will need to work out another way
Erika Epstein
GeNOS,
Try using the ID field instead. Much easier than Labeling. Do this in conjunction with other criteria such as Duane mentioned.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
opps. yeah thats what i meant.. im using the ID to filter the objects. my bad
thanks, it works
and do you usually give them ID before you place them?
nah... just later on when and if i decide i need or want a shecdule for them ill go and ID the items to suit
