Sure; has always been possible.
In your element schedule of (filtered) objects, just add the zone name and/or number from the 'General' list under Available Parameters for the scheme settings. Objects will then be listed with zones.
If you make the zone name/number be the first scheduled field(s) - by dragging them to the top in the Scheme Settings, you can then sort by zone and in the schedule window itself you can make the zones be 'headlines' (grouping titles). If you schedule BOTH zone name and number, then click Settings next to headline to group the first two parameters as the headline. You'll end up with something like the attached - which uses just the delivered "Object Inventory' scheme for the US template.
AC 28 USA and earlier • macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
