Selecting objects by properties
Does anyone know the following for the following ArchiCAD Calculation questions?
How do you...
1) Select objects/elements which don't have property objects linked to them?
2) Select objects/elements by the component key?
3) Select objects/elements by component code (ie. It selects all objects which contain a certain component in the property object?
4) Filter the above selections, ideally so that the selected objects are the only objects shown.
If anyone's got any ides it'd be great to hear from you.
Regards
Ian
Rob
Ian,
if you are referring to element schedule settings, I think it is not possible as the components and descriptors are not linked to the 'internal logic' of the schedules. I suspect that GS wants to either get rid of them or implement that later as for it was too risky to do it in one go along with new scheduling system, just a guess. I have actually asked for that before at:
http://archicad-talk.graphisoft.com/viewtopic.php?t=11364
::rk
