Set Up List Scheme - Start Format Assistant
While using the "Set Up List Scheme" I chose to use a "Graphic Template". I opened up the "Start Format Assistant" and created a layout name by dupliating one of the grayed out names. I then edited everything I needed. Upon completion I saved the .txt template file. The next day I started Arhicad and loaded my files and both my template and list scheme were there. However when I went to the "Start Format Assistant" the layout name I created was gone. Only grayed out names were listed. I am able to execute the lists to get my results, but after I restart Archicad I can no longer edit the graphic template.
If you can please help me or confirm that I am screwed 😛 it would be greatly appreciated!
Thanks!
2 REPLIES 2
Version of ArchiCAD? Platform? Etc?
AC 29 USA and earlier   •   hardware key   •   macOS Sequoia 15.7.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Archicad 10, Mac
