Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Set up list scheme CRASHES
I have been trying to learn how to use the calculate menu more, and one major problem I have been having is that AC9 crashes every time I try to open the "set up list scheme" command, I have completely uninstalled everything, and reinstalled to make sure it was not a preferences conflict or anything, it does work on a fresh install, but it does not seem to work with the new US library special edition, Any tips??
1 REPLY 1
Tibor Szolnoki
Dear Scott,
The crash is caused by a corrupt listset file in the SE library. To fix this problem please do the following:
- Extracting the SE library from the PLA file.
- Replace the LISTSET.txt file with the attached one in the List Templates 9\Property Data 9\GEN_Property Data 9 folder
We are working on a corrected version of the SE library which will be available soon. This patch will fix this issue.
Thanks for your patience
Tibor Szolnoki
Product Manager
ArchiCAD Product Management
