Importing a dwg with Cyrillic characters
I try to open a dwg file in ArchiCAD 8.1 on OS X.3.9 Which contain cyrillic Characters and I only obtain "?????". Same with the layers names.
In my conversion option, I choose to transfer all the polices not found to a cyrillic police that he does also with superb "?????" .
After opening, I can create on this file a block of text with the cyrillic police without problem —by choosing the russian keyboard…—.
Does someone had a solution to my problem ?
5 Replies 5
No one had this problem before ?
No idea?
No solution?
Djordje
No idea?
No solution?
True Type in DWG or SHX?
If SHX, do you have the SHX fonts used? Ask the guys to do eTransmit.
Is your whatever (can be Russian, Bulgarian, Serbian ...) Cyrillic keyboard on?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hello Djordje
Thanks for the Reply.
My Russian Cyrillic Keyboard is on.
I don't know if it is true type or shx. I don't receive a .shx file with the .dwg.
I make a try with the AC9 Demo Version and he works partially with the standard dwg translator.
The texts appear with little square and not with question mark.
If i change the font to a Cyrillic one of my system the good text appear.
Other point the missing fonts appear in my list of font when i edit a text in ArchiCAD.
On the other hand the layers name are always a beautiful collection of question mark as on AC81.
What is eTransmit ?
Oleg
Just tried it. Yes, on 8.1 INT I have ???? too
But on 9.0 RUS all is OK. ( I have no 8.1 RUS installed, but I think it will work too ).
Unfortunately, I have no good solution. But I think an easy solution may exists. May be it is required to change default archicad Font Script Code but I dont know Mac platform well. May be for this purpose editing resources is required.
I can offer little bit hard solution. It seems works, if autocad fonts were in the correct encoding.
Though layer names will not be actually cyrillic as the INT version does not use a cyrillic font for dialogues so it will look funny. Plan texst will be cyrillic if you choose cyrillic fonts.
You will need to enter 66 lines in the dwg translation dialogue : Miscellaneous / Character conversion:
ArchiCAD		AutoCAD
Character		Character
128 			 192
129 			 193
..... up to
159 			 223
Then
224 			 224
225 			 225
...... up to
255 			 255
And two more
221 			 168
222 			 184
May be anybody knows the right , easy solution.
That works in AC 81
Thanks a lot Oleg .
I can know work with the Russian "Autocadiste".
The text is change without question mark, the good russian text have now appear.
The name of layers also change but they become "specials" latin characters. I think if I have the menu in Cyrillic they will appear with his good name but these would be mine French layers names which would appear in special Cyrillic characters…
None is completely perfect.
Then thanks again Oleg
