I need to Export ArchiCAD into Navisworks, in NWC format?
I know there is an Add-on for this but I can't seem to find it.
Any suggestions.
Thank you,
Luis
KenMcN
I'd like to be able to do this as well.
Navisworks' web site <http://www.navisworks.com/support/file_formats/ch01s08.html> says it's possible "ArchiCAD can export to NavisWorks .nwc file format. JetStream does NOT have a direct reader for ArchiCAD files", but I can't find anything on Graphisoft's web site.
However it does look like .ifc files may now work - so perhaps this is another option?
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
If you have Navis on same seat as ArchiCAD, you can perform an export
http://www.navisworks.com/manuals/manuals.php?roamer/ch03.html#archicad_exporter
refers
The IFC reader is an alternative, but then so are the .dwg, .dxf, and .dgn outputs. None will be as good as the Exporter route
HTH
John
