Sheet Index
To All Users,
I am using the Project Index Sheet Index to generate my sheet index in AC12. I have two subset folders in the sheet layout, one which was for a planning commission review which included certain sheets from the second subset which is where my construction documents are. When I click on the Sheet index under the project map it generates all sheet in both folders, I only want those that are in the construction document folder of the Sheet Layout, any suggestions?
1 REPLY 1
I found that if you right click on the Sheet Index and click sheet index settings, add a criteria, subset in this case and select the appropriate subfolder, the list is then updated.
Yeah for me!
