Objects will be static, so no option to add doors/windows.
A quick google search shows you can at the very least find some detailed image files of drawings will all dimensions you need to draw your own container.
I'd probably draw the stud walls for insulation with composite, add some exterior air layer to add the windows to (with a thickness that works for how far I want the windows to extend beyond the container).
The container wall itself I would extrude with a shell, probably. Easy to add openings to (create hole).
Roof will need some insulation too, or it could be a green roof. Easy enough to do with roof or slab tool.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
