2006-08-27 01:37 AM
2006-10-11 10:44 AM
2006-11-16 06:27 PM
2006-11-17 04:15 AM
Sam wrote:so you posted here as well as randomly sending personal messages to people you think might be able to help you?
I am trying to import a SketchUp file with AC10. I downloaded the SketchUp for AC10 and put it in the import/export file of the Add-on folder. Yet I see no option to import under "Open", "Merge" or "Design Extras." What have I done wrong?
2006-11-17 08:48 AM
2006-11-17 03:50 PM
2006-11-20 04:50 PM
2009-09-02 05:51 PM
gkmethy wrote:I'm using AC v10 with the appropriate add-on trying to import a small test Sketchup file. Clicking the 'Import' button causes AC to close in about ten seconds. No warning message. I contacted support, sent them the file and they had the same problem. This happens with .skp v5 and v6. They implied the solution is to upgrade AC. Rather not. Anyone have a better idea?
We are happy to announce that the SketchUp® import add-on for Archicad 10 - International/German/Japanese for Windows® - has been launched. The SketchUp import add-on for Archicad allows users to easily re-use as much of the SketchUp model data in Archicad as possible, without the need to manually rework it.
2009-09-02 06:14 PM
2009-09-02 06:20 PM
Erika wrote:It would be an object that way, right? I would like to bring it in as slabs, walls, roofs as advertised. I've imported via 3ds. Thanks.
Try bringing it in as a library part.
2009-09-02 06:44 PM
