Sketchup to ArchiCAD
After successfully importing (File Special>Merge)a sketchup 3D file into AC 17, The resulting Morph is a quite lively bunch of polygons that are quite disruptive in obtaining a useful model to manipulate. I read online of a manner to eliminate extraneous polygons from the import on a windows machine, but not macintosh. Any suggestions?
Cleaning up an import via conversion to Morphs is the same on Mac and Windows:
http://helpcenter.graphisoft.com/tips/removing-triangulation-from-imported-sketchup-cinema-4d-and-3d...
See if that helps at all.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks so much, Karl. That cleaned things up quite nicely.
Great! Thanks for sharing - the feedback on the Help Center topic will be useful to others. 😉
