Sketchup to archicad import faces not co-planer
HI All forgive me for my ignorance I am a new user . I have been using Sketchup for some time now and have it mastered but I am bummed by the documentation side. I am now using Archicad (if you could call it using) and imported a very simple Sketchup model and all of the faces (walls and roof are not co-planer.
Its almost as if the import has pushed the top over and left the bottom where it was.
Any help would be much appreciated.
13 Replies 13
Hi Andrew.
Can you post a screenshot of what you get in Archicad after importing a model?
Which version of Sketchup and Archicad are you using?
Hi Sorry guys I am using Sketchup 8 and Archicad 15 . I am having troubles uploading the picture I have put the photo online and a URL here
https://picasaweb.google.com/lh/photo/9MsulRQ6HGhW10pNcAZeRA?feat=directlink
TMA_80
unless you import your model as a 3ds file and activate "force smooth" in the import dialogue box...i' can't see another solution...
AC12_27 |Win11_64bit|
Thanks for the input I will try it
I wanted to import several doors that I already have drawn into archicad and use them to show my clients how that actual product will look on their house.
I know when i render the model in archicad it works fine. is it normal for this to happen.
I watched a video made my Archicad that shows import of Sketchup models without this issue. I have 24 days left of my trial. I guess I may have to consider another product, Its a shame as Archicad is easier to use than revit.
I would also like to import several jobs I have at design stage and trace over but it is very hectic with all of these lines....
I know for sure the skethcup models faces are in plane. It appears as though Archicad import is skewing the model
I must admit that the video I watched was in Archicad 11, Maybe I should try get a copy of Archicad 11 and then export and put in 15. Is that possible?
TMA_80
Thanks for the advice and please forgive my lack of knowledge. I am learning reasonably fast but always get a few small problems. I exported from Sketchup as a 3ds file but when I go to import the file there is no 3ds option. I am guess I have to down load a plug in? I will check on line. Can you let me know if I am overlooking something?
TMA_80
in the help menu you should have access to the add-on web page...there, you will find the 3ds import add-on.
Thanks I found it and Imported the model and it is all ok
There must be a bug in the Sketchup import plugin.
I appreciate your help thanks again
I am glad TMA succeeded to help you.
He helped me too.
Cheers.
TMA_80 you are a good man
It works well with the add on. I have moved past that a fair way and now I have been importing windows. I would like to be able to import a window and have it cut a hole in the wall. From what I understand this requires GDL coding. can any one tell me where I can find the information required to get these wheels in motion
I would like to convert my entire library. I have had some help form Shrinivaz but he is not sure of the best way to go.
Thanks again for all of your help
