Skylight in schedules
Hi! happy friday.
I have a question: How can I include skylights in windows or doors schedule? or I can't
Thanks for any suggestion or help
4 REPLIES 4
You would need to set your schedule criteria up to include ... objects = windows OR objects = doors OR objects = skylights.
As well as any other criteria you need.
I am not so sure about how common the output fields will be for all these objects - ie size (width, length, height), handing, glazing type, etc.
You might end up with blank or duplicated fields in the schedule.
But I guess this will depend on what opbjects you are using and what info you want to get out of them.
Thank you for your answer, it is a good start, I will give a try
Thanks
thx for this question. i had the same question.
everyone, i created an object who has, one array parameter, like "Material Legend", and i saw that i can inventory all the values but only if used the text format in the basic list. Is there any chance to inventory if i used the graphic template ? or schedules list? Rolling Eyes
Thank a lot
