Mats_Knutsson
Mentor
Someone has a lisp to remove wipeouts in AC-generated dwg's?
Would be
AC 25 SWE Full
2 Replies 2
Until that happens, you could use 'Quick-Select' in AutoCAD to select all the wipeouts at once. They are defined as 'raster images' under object type.
Just wondering if the wipeouts are not generated from the background fills, which can be disabled in the DWG translator itself? (AC fills are exported as one hatch for the foreground pattern and another, optional, hatch for the background fill.)
