Having an issue with the unit conversion from archicad to autocad.  We do have a translator set up that we are using but I have also tried this with the ones that come with Archicad.  The translation go fine in Archicad.  Open it up in Autocad and everything is there.  However, when I measure something the units are Decimal and not Architectural.  Yes the translator is set to inches and I have also tried feet.  So if I check the units, ddunits command, it show them as Decimal.  Now the interesting part.  If I check the Project Settings then they are Architectural and then if I check the Units again they are architectural.  So I am guessing that the information is there but not translating properly.  Anybody else have this problem so seen this?  I am running Archicad 11 with the latest build.  Thanks.
