‎2013-03-21 12:15 PM
‎2013-03-22 02:41 PM
‎2013-03-24 01:31 PM
laszlonagy wrote:
Save the Object as a Morph.
Then modify the materials of its Faces and resave it as an Object.
When resaving all those different materials can be turned into parameters:
http://www.youtube.com/watch?v=4-Q0SQX21wQ&list=PL9B957359D5502D12&index=11
‎2013-03-24 02:49 PM
‎2013-03-24 04:23 PM
Matthew wrote:
If you plan to import more than one 3DS file from SketchUp you may need to edit the texture names. As I recall SketchUp uses generic texture names when it exports the bitmaps. On several projects I have had to rename the textures and then relink them on import to ArchiCAD.
