‎2021-01-20 02:15 PM
‎2021-01-27 11:24 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-03-08 02:47 PM
Minh Nguyen
GRAPHISOFT
‎2021-04-08 03:26 PM
‎2021-04-08 03:43 PM
Minh Nguyen
GRAPHISOFT
‎2021-04-08 05:38 PM
‎2022-08-22 03:05 PM
Hi Minh,
We have just had a very similar if not the same problem,
I had imported an XREF into my file, to which I then detached at a later date, (none of the layers were removed so had to do this through Attribute Manager, - which I understand is another issue.
we then go to import the same xref (with the same name) but from a different folder and it says the same error as above, that another with the same name exists.
I had reported this to the Graphisoft helpline which they confirmed that had not heard of, so I sent them to this post.
Are there any fixes as yet? as we dont really want to have the change the xref name
‎2023-06-09 06:36 PM
Hi Minh,
Is this still an issue in 25/26? I just tried to reload Xrefs on a teamworks file from the local work server, but don't have access to the server a home, so I decided to detach the xref and try to reload them off my home computer. I've successfully detached them in the xref manager but now can't reload them as I get the same error message as the original post. Is there a way to clear the "xref names" list that shows when you attach a new xref?
Of course I'm working on deadline, when I discover that this would be an issue, so any help ASAP would be greatly appreciated!
Thanks,
Cody
‎2025-05-22 02:05 PM
We are also experiencing the same issue in A28, exactly as described.
‎2025-05-23 03:39 AM
Do you need to place the DWG as an XREF?
You can just place it with the Drawing tool.
