Unable to place schedule in seperate .pln from original .plp
As is often the case this has probably been answered before and i just can't find it! So apologies if that is the case.
As the subject describes, I have numerous schedules which have been created in a teamworks file (they are all working wonderfully).
All i want to do is in a seperate solo project file, using the 'project chooser' - place a window schedule on to a layout.
If the teamworks file is already open, i get generating/updating drawing then eventually 'drawing is unavailable'. I have also tried placing the schedule with the teamworks file closed, with the same end result.
I suspect it is one of those odd AC quirks, where i am not using the correct trickery to get it to place the schedule. What would be great is if someone could tell me what the trickery is?
Thanks in advance.
Dan.
1 REPLY 1
In the file of the schedule create a View from the schedule.
Then try to place the View as a Drawing on the Layout.
