We value your input!
Uniformat 2010 Classification
John Dunham
Hi, I would like to find and import the Uniformat 2010 Classification into ArchiCAD 21...there is an earlier version of Uniformat in my copy but I need to use the 2010 version...I have the CSI/CSC PDF with all the categories of the system but I can't imagine having to manually type all of it into ArchiCAD...does Graphisoft or someone else have a file that can be easily imported?
John
___________________________
AC 25 (3002 USA Full) / Vectorworks Designer 2021
Cadswift Infinite Openings / Infinite Joinery Add-ons
27" Retina 5K iMac w/ 4.2 GHz Quad-Core Intel Core i7 and 32 GB 2400 MHz DDR4
OS X 10.15.7
4 REPLIES 4
Aaron Bourgoin
John,
http://www.graphisoft.com/downloads/archicad/BIM_Data.html
the UNIFORMAT II purports to be UNIFORMAT 2010
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-6000 USA
Rhino 8 Mac
MacOS 14.6.1
John Dunham
Hi Aaron, nice to hear from you again!
I'd forgotten about that page, but that's where I must have got the original version...
As you point out, there is some confusion around the version which Graphisoft is using as it refers version E1557-1997 and then in the pop-up window references Uniformat 2010 which are two different classifications although they have a similar origin.
The E1557-1997 version refers to a Uniformat II standard published by ASTM which has actually been superseded by a more recent version ASTM E1557 - 09(2015) (see <https://www.astm.org/Standards/E1557.htm>).
The pop-up window references Uniformat 2010 which is actually the one I am looking for and the one indicated in the referenced PDF. It is jointly published by CSI/CSC (see<https://www.csiresources.org/practice/standards/uniformat>).
I've never gone through and compared the two versions but this article hints at the confusion that can occur if both are used on the same project: <
<https://solibri.wordpress.com/2015/09/15/uniformat-check-ruleset/>.
I've emailed Graphisoft and they are going to confirm which version they actually used in their classification.
The attached screen snap shows the two referenced versions...
John
OS X 10.15.7
John Dunham
Kyla from Graphisoft has just informed me that they have revised the Uniformat classifications on their webpage...the one that was originally on the site has been correctly re-labelled as the 'ASTM Uniformat II', and they have also added the '2010 CSI Uniformat' classification...
<http://www.graphisoft.com/downloads/archicad/BIM_Data.html >
John
OS X 10.15.7
Aaron Bourgoin
Props to you John for following up.
Rhino 8 Mac
MacOS 14.6.1
