Using AutoCAD topo with 3d info in ArchiCAD
I have an AutoCAD file with 3d topo information. I heard something about use the Mesh tool in AC to use the Autocad "Z" information. Somebody know how?
7 Replies 7
I don't think there is any way with stock ArchiCAD, but the Architerra add on works well for this.
Goood document. Duane has always done nice work. This is the manual method of building a site mesh in ArchiCAD from a 2D DWG background. I was responding to your interest in using the DWG Z values.
AFAIK, IFC recognize sites made with meshes. What about using it to transfer from autocad (I mean Autodesk Architecture but actually, they give it to you with plain Autocad 2010) ?
Interesting thought. I haven't tried IFC site models. Do they come in as editable meshes?
BTW; AFAIK IFC is not a part of plain AutoCAD 2010, but is included in the MEP and Architecture versions (perhaps civil as well).
Karl Barker
I think it was a Cadimage tool, but not sure.
Last year we were did a large site (impossible to use contours to put in manually) around 500 hectares. We were able to get an XYZ data file from the surveyor which I understand is the raw data that they use themselves from the site survey.
The method we used was to Merge the XYZ data file.
This created a mesh with spot heights in the correct place on a grid as we determined to the surveyor.
It is nice when it is all automated.
Karl Barker.
27" Macbook Pro, M4 Max
48 Gig Ram
Mac OSX 26
AC 5.5 - AC29 (NZE)
Sounds like Architerra from Cigraph. I think it's the only add-on that can do this.
