Ian Fogden
Archicad and Vectorworks compatabili
Both owned by the same company are they compatible. ie able to import files between the two ? is there a way of doing this ?
runxel
While yes, same parent company, still separate programs from very different origins. So much so, that there is no direct way between them (but neither is there any between any BIM authoring tools...).
My question would be: What's the set-up and the goal here? Is it a one time job, or do you want to collaborate with another office using VW? ...
Many things to consider before you can get a good answer on a possible workflow here.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
IFC is a file format you can use to transfer models between the two applications.
However, most of an IFC file is not imported as native geometry in either (or any other) app, so an IFC is normally used only as reference geometry.
