β2005-04-21 02:21 AM
β2005-04-21 03:02 PM
β2005-04-21 07:42 PM
β2005-04-21 10:46 PM
Stephen wrote:Sounds like I work the same way as you do Stephen. I have only really used D&W Builder, the few times I have used the standard AC Library doors and windows I got frustrated by their limitations, and the lack of transfer of settings from one door to the next one you pick. I have got used to the layout of D&W custom settings, and it has improved with new releases (think I have R14 now?). Would still like to be able to make windows with more than 5 panels across sometimes (I know you can butt two together with end frames omitted) and Doors with sidelights that can be divided vertically as well as horizontally, but 99% of the time you can get exactly what you want, right down to exterior and interior trims, sill projections etc. Great program.
I agree with Tom, although I use it on EVERY project. I have saved a few windows and doors as "favorites", then modify those as needed. Saves time. ...
Steve
β2005-04-22 12:19 AM
β2005-04-22 01:08 PM
Gerald wrote:Gerald,
I also just got there Accessories Add-on and it is awesome for doing Board & Batten siding.
β2005-04-22 05:27 PM
