Kristen
Using TurnTool with ArchiCAD 11
The TurnTool plugin exists for ArchiCAD 11....is anyone out there using it?
I miss Zermatt (from the time when it worked) so I thought this might be a good alternative. Even though I follow the manual and have tested on a very small model and tried various alternatives amongst the options (including different unit sizes), I do not get a result that I can a) rotate/orbit without it disappearing into space; or b) walk in like the explore mode.
In fact, what I save out doesn't look at all like the demo files that TurnTool shows.
Is there anyone who has got this to work from ArchiCAD and can recommend which settings are best?
Kristen Broberg
AC 23 SWE Full on Windows 10 Pro
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
Hello Kristen.!
When you look at there forumsite at http://www.turntool.com/forum/viewforum.php?f=16
You can see, that it isn't the most used program for Archicad.
I wonder why?, because it looks pretty ok to me, and easy to use.!
They mention a problem of showing shadows when importing files from archicad. 3d studio has a feature called Texture baking, which solves that problem.
But they are working on implementing it in a future turntool viewer.
I am too curios of seeing some example made in Turntool.
Martin
