Wall accessories - wall framing
I am using Archicad 19 and I have installed the Accessories. I am trying to use the Wall Framing but I have the following two issues:
1. Wherever there is a door opening there are two lines showing [I guess they are the header]. Can I make then not showing?
2. The add-on creates the frame on the outer leaf of the wall so I have to move it to the correct place. Whenever I make a change to the frame though, it brings it back to its original location. How can I avoid this?
Do you actually find this accessory useful as compared to simply modeling the framing?
DGSketcher
Legend
I couldn't even get it to work, but from what I saw on the manual images I don't think the results would stand much credibility under structural assessment and possibly lacked sufficient flexibility to cover all the framing variables.
