We value your input! Please participate in Archicad 28 Home Screen and Tooltips/Quick Tutorials survey
2009-04-08 04:26 PM
2009-05-19 11:15 AM
2009-05-19 02:14 PM
2009-05-21 08:22 AM
Lipi wrote:Hi Lipi,
Thank you for your reply!
I think I may not have expressed myself clearly in the post (frustration might have had something to do with it). I needed to extract the wall areas, ie. the area they take up on the floor plan.
I ended up tracing them with different fills, which I think is probably the most time consuming way to get it done.
I'm sure there are much more effective ways, though. And easier.
I was worried about the SEO bit of the whole thing, and I needed precise values, so... fills it was.
2009-05-21 09:28 AM
2009-06-16 06:05 PM
Lipi wrote:Lipi,
Yes, I needed the area of the construction. The rooma areas I did extract from zones, and a good thing too, there was about 1500 of them
2009-06-17 05:59 AM
Lipi wrote:You can also extract the interior wall surface per room using the Zones. Make sure that they fill the rooms fully.
