Wall thickness in Door and window schedule
Hi, does anybody know if there is a way to add the wall thickness in door and window schedule?
Thanks
21 Replies 21
the left window connect parameter doesn't work for doors, can anyone assist me? is there any similar parameters for doors? I have checked all thickness related parameters .. but none seems to work
Hi Giuseppe,
recently I solved a similair problem with the Marker Text. I have attached this marker object which only puts the wall thickness in the Marker Text parameter.
Attach this marker to your doors and windows. Then in the schedule you get the field Marker Text and use it in the schedule
You can use this script in existing markers
