‎2009-08-21 05:35 PM
‎2009-08-21 07:51 PM
‎2009-08-21 08:30 PM
Peter wrote:Ahhh! (relief) That is what I must've done the first time without thinking and couldn't find when I actually put thought to it. I did type in "Set up list schemes" in the help menu and almost all results wanted to lead me to the scheme settings within Work Environment. Noooo, that's not what I was looking for AC, but thank you very much.
To edit, in the navigator right-click on the 'Lists'>'Zones' category to bring up the link to 'set up list schemes'.
‎2009-08-21 09:04 PM
ksymons19 wrote:The Room Categories List should be in the standard library. Mine's under C:\Program Files\Graphisoft\ArchiCAD 12\ArchiCAD Library 12\List Templates 12\Templates 12\Room_Categories.txt
...For some reason, I am not seeing the Zones / Room Categories in my default AC12 program. But that's alright, I will just create a new list scheme mirroring the settings of the one I found in an older file and version....
‎2009-08-21 09:50 PM
‎2009-08-21 10:01 PM
‎2009-08-21 10:05 PM
