Who can convert 2D Drawings into 3D Archicad ?
Just had a plan drawn using archicad and the I need someone to transfer the 3 x Townhouses that I have in 2D into 3D onto Archicad.
Does anyone know of anyone that does this and at what cost. I can supply a 2D dimension of the 2 story 3x townhouses and a 3D plan that was given to me on paper.
Total floor plan is approx 700m2
Any help would be greatly appreciated.
4 Replies 4
send me your drawings to [email protected] to check it out !
please check your pm !
Aaron Bourgoin
Some very clever Russians developed a plug-in called Plan2model to do this. It was done for an earlier version of AC and not updated.
One more in a long line of plug-ins that surface here and then disappear. Japanese shadow study plug-in anyone?
If you could track down the software and an earlier copy of ArchiCAD, you might be able to bring the model forward into a newer version.
Clever, clever Russians. When I grow up I think I'd like to be an oligarch.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
Erika Epstein
Plan2Model was ok; results were only as accurate as the dWG it was based on.
I recommend learning to use the program. With favorites set up properly constructing a model will be accurate, and can go quite quickly.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
