Use the ID field to distinguish the windows you want scheduled. For example, use an empty ID or "X" etc for those that you do NOT want scheduled, and a useful ID for those that should be. You can set the ID for an entire selected group at once.
In your schedule settings, use a criteria that has the ID <> empty / X / whatever to exclude the 'other' windows (or doors).
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
