We value your input!
Window schedule showing doors and walls
I just made a window schedule, but for some reason the schedule contains not only the windows (as specified) but also doors and some walls.
The only element I've specified in the settings is the windows. I've even tried to specifically make the schedule to not show doors, but for some reason they are still visible in the schedule.
The doors shown in the schedule are on the layers chosen in the settings, but they are door elements (not just wrongly labeled as such or similar). The doors do have glass panes in them, but this shouldn't affect their inclusion in the schedule since their element type is still door.
See screenshots for settings and schedule. Any advice?
If you don't want doors there is no need for a criteria to not include them.
The group of layers needs to be contained in brackets as well.
The brackets solved it! Thank you!
runxel
Legend
As a simple reminder:
Whenever you mix "and" and "or" in a schedule you will most probably need brackets. (:
