2023-04-21
11:55 AM
- last edited
a week ago
Aruzhan Ilaikova
it seems that the FILE_NAME in the exported IFC file’s header is wrong. (see screenshot)
The FILE_NAME should be the exactly the same as the name set up in the publisher (ARC_IFC4RV_SP in my case), but it turns out that the FILE_NAME also includes the full path where the IFC file is exported to.
This causes error when I put the IFC file to Trimble Connect. It says it can’t find my IFC file in this name (with the full path) when syncing the BCF file (long story.....) Anyway, This problem is solved when the FILE_NAME does not include the full path but only the file name.
I think this is a bug. Please fix it. Thanks.
Solved! Go to Solution.
2023-04-21 02:49 PM - edited 2023-04-21 02:56 PM
I use our ifc files on a local computer so I had no problem with that. But I checked and all ifc files I have exported have a full path description there. The Implementation Guide for IFC Header Section lists an example with the full path + filename though.
Our whole information network is MS based and we have parts of our CDE on Sharepoint with synced folders to local user-based computers. Now each ifc output has under it's name the corresponding username included in the path description..., which I don't like.
| Archicad 4.55 - 27
2023-04-21 04:20 PM
Thanks for your information. I didn’t know there’s a guide talking about this header.
I google it and found this discussion in the buildingSMART forum
https://forums.buildingsmart.org/t/about-ifc-header-section/2522/4
that it seems having full path name (either in Windows or Linux / Mac format) may either be not the original intent or it’s time to update the document.
It also says Revit, Archicad, blenderBIM all have different implementation on this field.
So it’s not a bug. I wouldn’t need to care about it if I had not used Trimble connect as CDE and BCF manager.
| Archicad 4.55 - 27
2023-04-21 04:20 PM
