Wrong UNICLASS 2015 En Table October 2020 xml in BIM Data Portal
daviddelven
There are missing Codes in the updated UNICLASS 2015 En Table October 2020 in the BIM Data Portal XML file.
(see attached image)
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I will report this to Graphisoft.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Minh Nguyen
Dear David,
Thank you very much for your report! It turned out that NBS made some small changes while keeping the same build version, therefore we were not aware of the changes. We updated the XML in our website to reflect this change!
Thank you once again for your report. Let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
