st
Wrong text height in external drawing from dwg import
I am an architect and I use both Autocad and Archicad for my projects (I also use windows 11).
In both apps, I model in 1:1 scale, using meters.
On my site plans I usually import the topography plan with drag and drop method.
As you can see in the screenshots, although the drawing element is already updated, the text height is wrong! (The drawing element is in auto-update mode).
The only way I found to make it look right is to right click it and choose manually Update again.
And even though I do the manual update and Redefine the view, if I close the file and open it again, text will look wrong again!
Am I doing something wrong or it is a program's bug?
Any help would be very appreciated!
[AC27 6020 INT FULL • HP Z1 STATION 12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz | 16,0 GB ram • Windows 11 Pro]
st
Am I the only one having  this issue???
