tdeschaumes
XRef layers
It's impossible to delete some layers that are come from an xref as you can see on the attached file.
Why ?
Is it a bug ?
Thierry Deschaumes
ACD GIRARDET & associés
MacOS 10.8|AC16
6 Replies 6
Thomas Holm
As long as the Xref is stil Xrefed, I don't think you can delete its layers. You would have to unlink it first.
i have the same problem. Even if i unlink all the xref's, can't delete the x-ref layers.
when the x-ref where "detached" we choose not to kept the x-ref attributes.....
Any ideas?
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Stress Co_
THIS Help?
Marc Corney, Architect
Red Canoe Architecture, P. A.
tdeschaumes
thank you for your answers which confirms the impossibility of erasing these xref layers.
So for me it's a bug.
I am in phase synthesis on an important project, I tested many solutions, xref, external drawing, none give whole satisfaction, damage.
Thierry Deschaumes
MacOS 10.8|AC16
Stress Co_
You can erase them. Try reattaching the Xref file.... then detach it using Xref manager. The layers wil be gone.
__archiben
that's the key to it: x-ref layers can only be deleted using the x-ref manager to detach the x-ref itself. otherwise they will sit in the file as locked orphan layers. it was an oversight on graphisoft's part that the new x-ref category of layer does not show in the attribute manager.
~/archiben
b e n _ f r o s t
