ArchiTiles, problem with texture
Hi, I tried to use the green texture on the tiles, but it cannot show the texture. The same texture is used on the desk (here it is showed right). Dont you know, where is problem? Thank you
21 Replies 21
You have to make sure that the engine (internal, light works, etc.) that is used for preview in the:
Options>Element Attributes>Materials...
menu, is the same that is used in the PhotoRendering Settings.
OK, I know. But here is the picture which show the settings of the green material. Where is problem? The tiles and the desk have the same material.
Dwight
When you mean "texture"" do you mean that you want the tile pattern to show in the green material?
Dwight Atkinson
When I do the tiles with the ArchiTiles, it want I choose material of the tiles. And I choose the green material which is shown on the ball.
I have tried to use material which is called as BARVA-07 ... and it works right (in 3D window i can see the right colour and in Foto LightWorks is the colour correctly). But when I use myself made material it does not work (in 3D window I can see only a gray colour and I cannot see the shape of tiles. It looks like it is covered by something).
This I can see in 3D window when I use material made by me.
And this I can see in 3D window when I use default AC11 materials (I can see tiles, here is it right)
Why does the tile do else effect than the block? Both has the same material
Dwight
The tile surface and the green surface ARE NOT the same material.
If you send me your file i will figure it out.
Dwight Atkinson
I do not know why it is not the same material. I have choosen the same material from material list. But OK, I send it to you. Thank you
