Zone Categories
I've been working in AC 12.
I have updated my zone categories through the attribute manager , changed the stamp "order" everything set to "none" apart from area , as I want to show nothing else.I saved the changes , chosen the modified zone category and when applied ,it listed all the different "orders" (floor finish etc) again , so I had to set it individually .Basically the updates I made to the stamp of the area category in the attribute manager , doesn't seem to be reflected when applied. Is there a way to resolve this?
Try to modify the default settings for those Zones in the Zone Categories Dialog.
Also, you may want to select all Zones using a certain Zone Category, assign to all of them another Zone Category and then assign them the original Zone Category again.
The reason for this is your Zones are already placed and the states of the various parameters are set for each Zone instance. It reads the default parameter states only when you assign to it a different Zone Category. So this is how it will work.
Koszi Laci
Szívesen. (You are welcome).
