Zone Lists ( very urgent :) )
How can I change the headings of a zone list?
Using a standard text format - everything shows up just fine.
However, if I turn on the graphic format the heading do not show as I have specified. Also, as you may see one the enclosed screenshot, measured area and net area show under totally different headings...
Also, it´s a bit strange that measured area and net ma. is the same...
Hopefullt there´s somebody out there who knows this stuff
Much appreciated!
Thanks!
You've got a textfile somewhere in your Graphisoft / ArchiCad directory, but I have swedish version and because of that my directory has swedish names.
But I think you could search for .txt files in your library directory and you will find this textfile.
Thanks, I think this will work
