Zone wall surfaces
I've tried to calculate wall areas using zones. The idea is to show in a schedule the wall, floor and ceiling surfaces and areas of each room in a building.
So, there is no problem when the walls are not intersected by columns or beams. But when they are, the wall area is reduced, because apparently the schedule only calculates "wall" surfaces, excluding beams and columns.
My question is: how do i create the schedule i need, that shows the correct area of vertical surfaces of a zone?
0 REPLIES 0
