Zones and volumes in schedules
- i have a plan with zoning marked in m2 - i.e. floor space.
- schedule created
- volume in m3 is incorrect because there is a mezzanine/duplex double height space. how do i treat this so its recognized in the schedule listing under volume
The question is how to show this double highest space in the column in then schedule under volume. presently its only CALCULATING the floor area plus wall halls associated to the actual floor space and not the void space in the atrium area with a double height space.
Ground floor is approx 60m2 with a 3m Floor to ceiling. However part of this 60m2 is designated to having a double height space which is not being calculated in my zoning schedule.
ThX
Siad
1 REPLY 1
Select the Zone in question and go to its Settings Dialog.
In the Name and Positioning panel, you can define the Height of the Zone. Currently it is probably set to be single-story height. You can modify that so that it will have the desired Height.
