Zones
Maki
I am having a problem with the zone tool, after I use it with Inner Edge lets say to give me the m2 of the bedroom, after that when I make changes to try to circle around something with the same zone stamp the number of the measurement doesn't change.
Any idea where is the problem?
I will shot it with 2 screenshots compered as the number doesn't change.
Miha_M
Menu Bar > Design > Update Zones
| Archicad 4.55 - 27
I know that feature but in previous projects where the problem i have now was normal and wasn’t like that.
thanks though!
If you use Polyline/Manual Zone boundary, then the area information updates "on the fly". If you use inner edge then you need to use the "Update Zones". Inner edge relies on a boundary that is not the zone itself...which means that if you start pulling the corners then it cannot measure as it has no connection to the boundary.
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
