archiforma 3d_polylines to robot millenium
Has anybody an idea how to save Archiforma 3D_polylines to any 3d format accepted by robot millennium ?
Thanks.
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Once you have created you 3D Polyline, exporting it’s an ArchiCAD task!
I mean in order to export the data you are not using ArchiForma anymore but the ArchiCAD standard procedure.
So, ArchiCAD will export the 3D data depending on the Save as… command you will choose.
I don’t know which kind of file formats Robot Millennium can import…
If it provides the users with a file format that ArchiCAD uses it shouldn’t be a trouble.
Of course anything depends on which kind of entities it can import and if this import matches with what you are looking for.
If, as I could suppose, you choice will be the DXF or the DWG format, then what I can say is that the ArchiForma 3D Polyline is just a “normal” GDL object so it should be exported as BLOCK entity.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
What is "robot millennium"?
Sounds like a question for the robot's forum.
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
ROBOT Millennium - civil engineering software, structural design and modeling
this is what I got by looking for it on internet...
Fabrizio Diodati
