begginer problem with architerra
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-09-20 03:50 PM
‎2009-09-20
03:50 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-20 10:20 PM
‎2009-09-20
10:20 PM
You may need to give us a little more detail on your procedures.
If you imported the DWG using Architerra then the likelihood is that it did not contain any 3D data. If you imported (ie merged or placed as drawing) using ArchiCAD's built-in functions then you will only get 2D elements. (ArchiCAD can only import 3D DWG as a library part and this is of no help to Architerra.)
There are several ways to input the 3D data manually if you don't have it in the DWG. I don't have time to go into it here. You should take another look at the Architerra docs for the details or can try a search here on the forum and wiki.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-20 11:21 PM
‎2009-09-20
11:21 PM
ok i had file in dwg, so I opened it in autoCad and saved as DXF.So obviously it isn't 3D file isn't it
and imported it via DXF tool in architerra palette.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-21 08:46 AM
‎2009-09-21
08:46 AM
Sometime reading the user manual could help...
Importing the data using DXF or TXT format is not enough: I mean in this way you just imported the data describing the terrain but you still don't get the terrain model.
You have to define the terrain perimeter by using the Ourline tool and then build the terrain using the Terrain tool.
Friendly
Fabrizio
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
