calculations
hallo, I try to start using calculations and lists, but in the manual says that first I have to add some comands to the existing menus, such as
• Set up List Schemes
• Edit Database
• New Properties
• Edit Properties
• Last Selection’s Properties
• Link Properties to Criteria
Unfortunately I can't find them in
Options > Work Environment > Menus
Please tell me what am I doing wrong
Thank you
1 REPLY 1
David Maudlin
leontidisantonis:
In the Work Environment > Command Layout Schemes > Menus, set the Application commands and menus (middle column) to All commands by theme, then scroll down to the 16 Calculate folder to find these commands. These are the old List Schemes, which have not changed (or been improved) for years. You should look at the Interactive Schedule to see if this will work for you: they are more intuitive and you will find more help on this forum for them.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
