documentation using the construction IFC model
if anyone has done the documentation of architecture using the construction IFC model?
In other words, if someone was working on a REAL FULL BIM project?
what is the problem, IFC export is set with the option of BREP (others are incomplete) after imports to the AC elements are as objects...
of which is known can't be done cross-section!
helps only MORPH option, but we would lose all data, even GUID!
if any had this problem?
0 REPLIES 0
