I carefully go through the door setup, setting w/h/thickness, material, finishes, adding information I need to the parameter settings (user defined comments 1, 2, 3 etc), saving as favorites...D1, D2, etc.
Push the create schedule, select the items I want, add "additional parameters" to take care of the information you don't include that I want (see paragraph above) and what i get is
anybody's guess as to where it came from.
What i can't seem to iron out is where/how to set the door panel thickness to be what I want, not some weird number, or, if I get a weird number, please let it be EDITABLE.
IT SEEMS LIKE I CAN ACHIEVE EVERYTHING THAT I WANT, EXCEPT ONE NON-EDITABLE BIT OF INFORMATION, WHICH MAKES THE ENTIRE SCHEDULE USELESS
