dwg/dxf translator causes crash
Whenever we try to export dwg/dwf files it causes a crash. Either through save as or through publisher. Even just opening the translator setup causes a crash. I assume the translator is corrupted somehow but I'm not sure how to fix it since every time we access it through archicad it kills it.
1 REPLY 1
I have the same issue a year after your post. I crash in publisher when I try to publish .dwgs, or when I hit the options button to try to set up the format (or whatever is under the options tab, I don't' really know). Any help? Thanks.
I am simply highlighting my elevations, plans crash too, and hitting publish. Sometimes the saving dialog comes up and it crashes when I hit continue. I crash immediately if I hit options.
